What is this leak ???
Old Aug 2, 2006 | 06:16 PM
Toddman0025's Avatar
Toddman0025
Default What is this leak ???
I pulled out of my driveway and discovered a puddle of transmission fluid (?) under the car - after jacking it up I traced the leak to this thing - front drivers side near the wheel (you can see the red drip). What is it and how do I fix it? (1969 Grande 2 Door Coupe)
Old Aug 2, 2006 | 06:47 PM
laserred02's Avatar
laserred02
Default RE: What is this leak ???
are you sure it isn't power steering fluid? that would make more sense if it is up near the front of the car, i would check the power steering system...that is if you 69 has power steering
Old Aug 2, 2006 | 07:49 PM
Deannostang's Avatar
Deannostang
Looks to be power steering fluid. Check your reservior for missing fluid.
Old Aug 2, 2006 | 07:50 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Tranny cooler line leaking? Does it go from the tranny to the radiator?
Old Aug 2, 2006 | 11:34 PM
Cobrakev's Avatar
Cobrakev
Like said above, looks like power steering fluid to me.
Kev
Old Aug 2, 2006 | 11:53 PM
WhiteStang01's Avatar
WhiteStang01
Has to be power steering fluid especially since the lines are on the drivers side, the trans lines are usually routed to the passenger side to the radiator or external trans cooler. It may be the lines that are going to the steering gear or rack. [sm=badbadbad.gif]
Old Aug 3, 2006 | 12:52 AM
kartracer55's Avatar
kartracer55
Im guessing power steering as well. Ford are notorious for power steering problems as well.
Old Aug 3, 2006 | 12:54 PM
Twister's Avatar
Twister
use ATF when filling it
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
