CUTTING FACTORY SPRING'S. WILL IT WORK?
Old Aug 9, 2006 | 01:45 PM
westtndad's Avatar
westtndad
Default CUTTING FACTORY SPRING'S. WILL IT WORK?
I am wanting to lower my 99 mustang about 2 inche's. I know I can buy spring's that are all ready to put on and lower my car, but I was woundering why cant I just cut my factory one's? I know I dont need to heat them up but if I cut my factory one's will it hurt the spring any and how will it ride with the factory spring's cut?
Old Aug 9, 2006 | 02:02 PM
2k1gt's Avatar
2k1gt
Default RE: CUTTING FACTORY SPRING'S. WILL IT WORK?
Dont do it. You will mess up the spring rate if you cut stock springs. If you want to lower your car 2" for cheap buy some used frpp c-springs and cut them.
Old Aug 9, 2006 | 02:55 PM
mustangman02232's Avatar
mustangman02232
you can, but i dont recomend it, do it right, its not a cheap honda
Old Aug 9, 2006 | 06:22 PM
amrcnidyot's Avatar
amrcnidyot
ive heard it will ride like crap. and no matter what, if you lower it more than 1.5, youll need new cc plates too.
Old Aug 9, 2006 | 10:46 PM
ExtremeSaleen's Avatar
ExtremeSaleen
I remember my brother cutting the coils on an S10s to lower them back before companies were making them. He would only cut just a little bit then heat up and flatten a coil out. The trucks had a rougher ride, but not too bad.
It can be done, but if you don't know what you're doing, you'll probably beat the hell out of you and the car because the ride would suck. Not worth it when lowering springs are so cheap.
Old Aug 10, 2006 | 02:12 AM
dirtysanchez's Avatar
dirtysanchez
I ♥ Acer
the springs are that size for a reason. when you cut them you take away the spring's integrity. dont do it. just buy some or you will regret it.
Old Aug 10, 2006 | 10:37 PM
westtndad's Avatar
westtndad
what are "frpp c-springs" and where can i get them?
Old Aug 10, 2006 | 11:06 PM
Vash the Stampede's Avatar
Vash the Stampede
i actually cut my springs. and wow what a mistake.... because my strut was hanging out of my hood after hitting a pot hole on the highway.
i really wouldn't recommend it.
Old Aug 10, 2006 | 11:19 PM
sweet99's Avatar
sweet99
If you cut springs their rating will probably quadruple, meaning very stiff! Buy Eibachs from eBay. mark
Old Aug 10, 2006 | 11:58 PM
AXLE's Avatar
AXLE
traction will suck too!
