Need HVAC help fast!
Old Aug 10, 2006 | 01:43 AM
1fast97gsx's Avatar
1fast97gsx
Default Need HVAC help fast!
My car only blows air out of the defogger vents way at the front of the dash. I charged the AC and want to use it but the car just doesn't get cold from air just blowing at the windshield. I tried another HVAC control unit and it didn't help either. How many vacuum lines run from the engine bay to the inside of the car to the unit? Maybe 1 jsut isn't connected for whatever reason. Any other ideas? This is my daily driver so I need air! 1995 mustang gt.
Old Aug 10, 2006 | 07:42 AM
xzo6's Avatar
xzo6
Default RE: Need HVAC help fast!
Just let the Dealer repair it under warranty.Sure sounds as if the problem has alot to do with your control unit in the car.Is it an Automatic control system or manual? Could there be a blockage in the duct work(ie)did a small object fall into the defogger vents.Has the car ever been in an accident? Did it do this prior to your A/C recharge?Seems coincidental...
Old Aug 10, 2006 | 08:01 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
You have a vacuum source problem. Look around under the hood near the pass side firewall for any that are disconnected.
Old Aug 10, 2006 | 12:35 PM
02StanGT's Avatar
02StanGT
ORIGINAL: PRO50SC
Bingo
Bokeo
Oct 10, 2015 08:28 PM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
ctgreddy
Sep 20, 2015 08:35 PM
Sep 16, 2015 07:53 PM
