WTF is a valve tap
Old Aug 10, 2006 | 09:22 AM
Zincpony's Avatar
Zincpony
Default WTF is a valve tap
ok soo i nkow what a knock, ping, tap, or a lift sound like on a car. but what is it actually i dont know. can someone please explain.
thanks. and how can it be fixed.
Old Aug 10, 2006 | 12:33 PM
02StanGT's Avatar
02StanGT
Default RE: WTF is a valve tap
when the valve hits the piston
Old Aug 10, 2006 | 03:50 PM
Zincpony's Avatar
Zincpony
how is it fixable then.
Old Aug 10, 2006 | 06:33 PM
02StanGT's Avatar
02StanGT
The reason it happens is either: 1) You have aftermarket cam/s which push the valves in further, thus hitting the pistons, or 2) timing chain has slipped or cam timing is off, thus valves going in sooner/later then they need to and hitting the pistons. Solutions are get dished pistons, or see if cam/s and crank are lined up right. Hope this helps. Also, it would be a good idea to check the condition of the valves and pistons if this has happened.
Old Aug 10, 2006 | 11:23 PM
Colorado_Mustang's Avatar
Colorado_Mustang
I think you're referring to the soft tapping sound when the rocker arms are too loose, or the mechanical music a solid lifter cam makes. The fix is to properly lash the rockers/lifters for hydraulic cams, and to properly set the lash for a solid lifter, keeping in mind you'll always here the tap with the solids. If you can't get the tapping out of a hydraulic, you may have a bad lifter, or one that isn't designed for an aggressive cam.
ORIGINAL: Zincpony
Old Aug 11, 2006 | 11:01 AM
Chopper's Avatar
Chopper
Here is a list of common noises.
http://www.bullittarchive.com/7019.htm
Old Aug 11, 2006 | 03:09 PM
monkeydude3's Avatar
monkeydude3
how many miles on the engine, sounds like a lifter or two are shizzot.
Old Aug 11, 2006 | 07:22 PM
Zincpony's Avatar
Zincpony
82k, daily driver. i drive my car for work and everything. the noise is very bad when the engine first starts out. and then it lowers but you can defenetly hear it if you pay attention even after the car gets warmed up and the oil is pumping and its sitting idle..
Old Aug 11, 2006 | 07:52 PM
02StanGT's Avatar
02StanGT
Sounds like the aforementioned lifter problem
Old Aug 12, 2006 | 12:16 AM
monkeydude3
yup... you may want to try running a thicker grade of oil for the time being or a bottle of oil treatment.
My car has bad valve guide seals, and I run 5w30(soon to be 10w30) valvoline max life oil. I added a bottle of the max life oil additive, and it seems to have decreased the engine smoke by about 50%.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
lmurf60
Sep 24, 2015 10:07 PM
