Weird noise from the rear...
Old Aug 13, 2006 | 05:54 AM
yetihairball's Avatar
yetihairball
Default Weird noise from the rear...
Hey, About 2 months ago I started hearing a weird rattling noise coming from the rear passenger side of the car whenever I went over any speed bumps. Now, I am getting a weird scratching/grinding noise...but it only happens when I shift from reverse into 1st, and begin to accelerate, and it only happens on an incline. Normal driving, the car is just fine.
I found that the passenger side trunk hydraulic lifter thing is slightly loose and rattles. I figured that's what the rattling noise was, but now that I'm getting a scratching/grinding noise from the same area, it makes me wonder if there isn't a more serious problem.
I duct taped the hydraulic lifter so that it would not rattle and I am still getting the grinding noise.
Any help or suggestions are appreciated.
Old Aug 14, 2006 | 12:43 AM
03truebluegt's Avatar
03truebluegt
Default RE: Weird noise from the rear...
I had what sounds like the same problem and it ended up being that the whole rear end was loose. I took it to the dealership and they tightened it right up, never heard the noise again. i would just take it to a mechanic and have them play with it to see if they can figure it out.
Old Aug 14, 2006 | 12:22 PM
monkeydude3's Avatar
monkeydude3
ORIGINAL: 03truebluegt
dunno why but that made me laugh
but yeah with this situation, it is much much easier to diagnose if you have a lift. It can probably be done if you jack the back of the car way up and get under there with a fine toothed comb...
Old Aug 14, 2006 | 06:14 PM
xzo6's Avatar
xzo6
I am going back to the Dealer tommorrow.They installed an adjustable Panhard rod.Roush shocks,lowering springs and a Roush sway bar.Now I get a clunck over bumps.I assume something isn't torqued correctly.Coincidently it's on the passenger side rear as well.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
KingRando
Oct 2, 2015 08:06 AM
69Volunteer
Sep 30, 2015 10:39 AM
mungodrums
Sep 28, 2015 10:54 PM
MasterLanMan
Sep 13, 2015 08:21 PM
