Wiring problem need help
Old Aug 14, 2006 | 01:28 PM
kenkorsak's Avatar
kenkorsak
Default Wiring problem need help
Hello, my son has a 67 mustang and we have a wiring problem. All the lights work except for the brake lights and turn signals. I found the brake light switch bad so I replaced it. Now the brake lights come on but so does the front turn signals and the turn signals on the dash. When the brakes are applied all these lights come on until you let go of the brake pedal. The turn signals still do not work. I have no power going to the flasher. The book says to disconnect the flasher and put a jumper wire and one of the turn signals should work, not. Any help would be great.
Old Aug 14, 2006 | 01:42 PM
67Sally's Avatar
67Sally
Default RE: Wiring problem need help
What book are you using? I'm not entirely sure what would cause that but a shop manual might help you out.
Old Aug 14, 2006 | 06:07 PM
xzo6's Avatar
xzo6
I would think that if all your wiring is correct,and there are no obvious shorts in the wire harness,you have a ground problem.Older cars are sometimes corroded (or simply have a bad connection)at the ground.If you already checked for them you ,I am unable to think of anything else.
2007StangV6
Jan 28, 2016 06:09 PM
Doogie65
Sep 6, 2015 02:55 PM
zanemoseley
Sep 6, 2015 12:58 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
