Another problem with the navigator...
Old Aug 14, 2006 | 10:18 PM
StangMan1010's Avatar
StangMan1010
Default Another problem with the navigator...
ive noticed this for about a mouth now..and i think nows the time to address it...
i notice whenever i make the hard right into my drive way i hear a loud "CLANK" noise from the front suspension...and when i hit the crub to go into the driveway..i hear the clank noise again...
i am thinking its the tie rod, or wheel bearings....could also be a strut..
does anyone know what the problem could be?
Old Aug 14, 2006 | 11:32 PM
GreyStang's Avatar
GreyStang
Default RE: Another problem with the navigator...
If your only hearing the sound while hard cornering it's probably either the CV joint or U joint whichever one the Navigator uses
Old Aug 14, 2006 | 11:34 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
I kno the sway bar ends go bad on exploders all the time. It looks like a little metal rod coming from the sway bar to the control arm. Will break. Not sure about expeditions.
Old Aug 14, 2006 | 11:41 PM
Cobrakev's Avatar
Cobrakev
+1 on what White Fox said. The Fox body Mustangs do the same thing. Best way to find out is to put the frontend up on jackstands so the wheels drop all the way down. Put the stands under the frame. You will then see if they are broke.
Kev
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
