Fuel Filter Change
Old Aug 15, 2006 | 11:23 PM
Ghia1's Avatar
Ghia1
Default Fuel Filter Change
First let me say that the car in question belongs to my girlfriend.
She tells me that it's a 3.8 liter '98.
I just changed the oil, oil filter and air filter and am attempting to change the fuel filter. I found and disconnected the pressure switch and ran the car until it stalled. I then removed the clips from either end of the fuel filter but I'm unable to pull the lines free from the ends of the filter. The hose ends that are attached to the filter appeared to be stainless steel. This is different than I am used to seeing but then I've not changed a fuel filter in a pressurized system before.
The filter spins easily within the hose so it seems loose enough that it should pull off. Is there a special tool necessary that spreads between the filter and hose end that spreads to push the hose off?
Old Aug 15, 2006 | 11:31 PM
pete1665's Avatar
pete1665
Default RE: Fuel Filter Change
ORIGINAL: Ghia1
yes there is a tool that you need. you should be able to rent it from an auto parts store. I instead cut the line off of each end of the filter, then just used hose clamps and rubber fuel line to put the new filter back on ( didn't know about the special tool at the time... ).
Old Aug 18, 2006 | 03:12 PM
jcassell1's Avatar
jcassell1
Can anyone show a picture of this special tool, its name and where to get one. Thanks...
Old Aug 18, 2006 | 03:17 PM
monkeydude3's Avatar
monkeydude3
buy this kit
http://www.sjdiscounttools.com/lis37000.html
monkeydude3
u can get it at autozone, lee, carquest etc it's a pretty standard item... even sears has it
Old Aug 18, 2006 | 03:27 PM
amrcnidyot's Avatar
amrcnidyot
some of the fuel filters come w/ the tools. the one i got did. dont remember the brand but it came w/ the 2 little clip things
Old Aug 18, 2006 | 03:30 PM
monkeydude3
i thought those clip things held the new filter in.
With ours, I believe you remove those little clips, then use the line tool to click loose the fitting, then pull the filter out. You snap in the new filter, and then put on the little clips.
waiittt.... with ours you don't even need the special tool it's just held in my those clips. da lmao
Old Aug 18, 2006 | 05:41 PM
SleepingGT's Avatar
SleepingGT
ORIGINAL: monkeydude3
buy this kit
buy this it cost a few dollars, worth it
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
whatsup62
Oct 16, 2015 03:07 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
