Whistle Noise
Old Aug 16, 2006 | 12:35 AM
chriscindy6369's Avatar
chriscindy6369
Default Whistle Noise
I get a whistle noise after the revs come down after stepping on the gas. When the car is at idle it's fine after acouple of mins but when i step on the gas i get the noise. It's coming from the throttle body side. it just started to do it.. Thank smuch. I'ts also supercharged..
Old Aug 16, 2006 | 12:57 AM
samseed101's Avatar
samseed101
Default RE: Whistle Noise
Before I read the last line, i was going to be a wise *** and say "maybe it's supercharged"
LoL, superchargers are supposed to whine. Well, depensing on the model they are. But if you have a S/C and it's whining, be happy that it's working
Old Aug 16, 2006 | 03:20 AM
backinblack06's Avatar
backinblack06
ORIGINAL: samseed101
He said whistle not "whine" [sm=icon_beat.gif] But there is nothing sweeter than a S/C whine I agree !!
Sounds like you may have an air leak somewhere.
Old Aug 16, 2006 | 04:29 AM
alexr's Avatar
alexr
you can switch that whistle to a whine with a nice KB upgrade
Old Aug 16, 2006 | 11:10 AM
samseed101's Avatar
samseed101
whistle...whine... people call it different things and different S/C's make different sounds. I've always called it a whine instead of a whistle when I hear a turbine or something spooling up. Guess it's just the pilot in me. Either way, i still think it's normal (unless we know what typwe of S/C it is and we can hear a sound clip.)
But boy do they sound nice!!!
Old Aug 16, 2006 | 01:20 PM
xzo6's Avatar
xzo6
Sounds like a vacuum leak under the hood.
Old Aug 16, 2006 | 02:13 PM
88scgt's Avatar
88scgt
my car had same problem for the longest time. it is not a vacum leak, that is what we thought. if you have a larger throttle body, it is air coming through the throttle body because it dosent close all the way. what i did was take throtle body off intake and drill a 1/16 inch hole in the flap, this will let air go through the hole instead of around the flap. since i did this it has not whistled, except for the s/c
Old Aug 16, 2006 | 04:15 PM
alexr's Avatar
alexr
ORIGINAL: 88scgt
ya probably shouda just cleaned out your IAC
Old Aug 16, 2006 | 09:38 PM
88scgt's Avatar
88scgt
ya for some reason i think i did that quite a few times and oh wait it didnt stop it, then i replaced the iac so for some stupid reason i called the manufactors of my throtle body and the said that my size throtle body they had problems with this and that the solution was exactly what i posted earlier.
Old Aug 19, 2006 | 10:39 AM
chriscindy6369
OK i know i have some Air leakage from the Shaft side and also on the other side. I ordered gaskets and I'll try that. I know 100% it not the Chargers Whine ... But 100% some air leak. I'll take a look into the problem and let you all know what i find thanks much
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
69Volunteer
Sep 30, 2015 10:39 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
