distributor ?
Old Aug 18, 2006 | 05:04 PM
floridastangs's Avatar
floridastangs
Default distributor ?
Here's a good one. Looking to put new distributor in mustang. is a '90 model block different that a '80's model block? The mallory distributor I have is about half an inch shorter than the stock distributor. Will this still work?
Old Aug 19, 2006 | 04:58 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: distributor ?
Shorter where? The important dimension is what actually goes into the block, not the part sticking out. As far as I know, the 302 block is the same through the ages as far as dizzy's are concerned.
ORIGINAL: floridastangs
Old Aug 19, 2006 | 02:02 PM
floridastangs
It's short at the end of the gear about half an inch. the fuel inj. dist. is 5 -1/2 from where the dist. sits on block the the oil pump shaft.
Old Aug 19, 2006 | 02:17 PM
Colorado_Mustang
Roller cams require a different gear than flat tappets. Could you post a pic of the two side by side lined up by the shoulder where they sit in the block?
Old Aug 27, 2006 | 02:51 PM
floridastangs
The gear is the same but from bottom of gear to end of shaft is shorter that the FI distributor.
I have pic's but not sure how to post them?
Old Aug 27, 2006 | 03:23 PM
67Sally's Avatar
67Sally
Below the text box when you hit reply there is a button that says "click here to upload". It's pretty self explanatory from them. If you need to resize it do it in MS Paint using "sketch/skew".
Old Aug 27, 2006 | 06:06 PM
floridastangs
Thanks for the help. This is the efi distributor it's 1/2 inch longer than the 1962 - 1980 distributor from the bottom of gear to the end of shaft.
[IMG]local://upfiles/45395/4A3F10753CFC4EA9BF042337062BDF90.jpg[/IMG]
[IMG]local://upfiles/45395/BF6505FA012D481FB6B3A6CD777AA290.jpg[/IMG]
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
StalkerGT
Sep 25, 2015 02:41 PM
dalehunter
Sep 25, 2015 10:51 AM
jaiidutch
Sep 14, 2015 10:29 AM
