2000 Mustang won't start
Old Aug 23, 2006 | 05:54 PM
kennethross's Avatar
kennethross
Default 2000 Mustang won't start
I have 2000 Mustang 3.8L. A few weeks ago, it was backed up into in the parking lot and since then I have been having trouble getting it started. It wouldn't crank over. If I did get it to crank over, it would be during the morning or at night when it was cool outside. I tried resetting the fuel pump switch a couple days ago and this only made it worse. Now the car won't get any gas, causing the car not to start at all. Can anyone help me out on this???
Old Aug 23, 2006 | 05:55 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: 2000 Mustang won't start
Not cranking over... sounds electrical
Does it crank over fast or slow?
Old Aug 23, 2006 | 06:03 PM
kennethross
Right now the engine isn't cranking. When I try to start it up, I would have to say that it tries to crank over fast. But its not getting any gas now after resetting the switch. I dont know what to do other than taking it in to the shop and spend hundreds of dollars.
Old Aug 24, 2006 | 03:26 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
Don't be so quick to jump to the fuel PUMP
If I was you I'd go...
1. Fuel filter
2. battery
3. starter
IMO most likely the starter...but I always like to go from easiest to hardest. fuel filter is probably like 10 bucks...battery maybe 50 bucks...& starter is just a pain in the a$$ (i would guess...never replaced teh starter...BUT IF YOU DO...Don't forget to take off the battery terminals and cover them.)
GL
Old Aug 24, 2006 | 03:32 AM
Anthonyandmarisol's Avatar
Anthonyandmarisol
read owners manual on resetting the switch sometimes you have to do more than you think to reset it, after that i would check the fuel pump and also if you may have think you hit the gas line somewhere backing up check that also you could have crimped it but thats iffy, i would check the fuel pump and fuses good luck
Old Aug 24, 2006 | 09:35 AM
clearym's Avatar
clearym
Won't start? Are you sure its not a Chevy?
mmbrown
Sep 8, 2015 01:29 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
01blackgtconv
Aug 14, 2015 04:50 PM
daytooday
Aug 11, 2015 09:22 AM
01blackgtconv
Aug 10, 2015 01:25 PM
