brakes and suspension
Old Aug 24, 2006 | 10:11 AM
1985cj7's Avatar
1985cj7
Default brakes and suspension
i own a sn95 gt i have the usual bolt ons and 373 gears im looking to upgrade the front and rear suspension a little along wiht the brakes because a supercharger is in the future i would like input and ideas please i dont want to spend an arm and a leg and can do the work myself. i have already purchased and installed 90/10 and 50/50 shocks i have a set of lift bars that ned elded on but ive heard bad things about using these??? also as far as brakes go could i get a set of cobra calipers and rotors and being good there or is there a better way to go?? thanks for your suggestions.
Old Aug 25, 2006 | 07:56 PM
1985cj7's Avatar
1985cj7
Default RE: brakes and suspension
Old Aug 26, 2006 | 05:08 PM
99sbm's Avatar
99sbm
i would get a good set off upper and lower rear control arms. im using UPR they were $216 shipped for both upper and lower. also i would get a adjustable pinion snubber, and subframe connectors, and maybe some drag springs. i dont run a front sway bar on my car, lots of people say it is dangerous, but as long as you remember that your dont handle well and slow down around curves you will be fine. here is how my car is setup: QA1 tubular chrom-moly K-member W/ matching A-arms, Lakewood 90/10's, UPR coil overs,no sway bar, flaming river manual rack, UPR subframe connectors, MAC pinion snubber, UPR rear control arms, Lakewood 50/50's, Moroso "trick springs", motive 4:10 gear, moser 33 spline spool, moser 33 spline 9" axles, Moser 8.8" style 9" housing ends. for brakes im using stock calipers, power slot rotors and hawk pads. i would upgrade my calipers, but i cant find any that will clear a 15" wheel that i can afford. it still stops better then it did from the factory.
Lethaldosage423
Oct 19, 2015 12:12 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
marc954
Sep 29, 2015 11:18 AM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
