Transmissoin shifting
Old Aug 26, 2006 | 01:34 PM
floridastangs's Avatar
floridastangs
Default Transmissoin shifting
Here's the problem my transmission started not going into gear so I changed the filter and fluid worked little better but now it will not shift on it's on. also drive or over drive will not work. It shifted into drive today like nothing was wrong but I stoped at stop sign then it went right back to not shifting again. Is there a shift senser or Vac. shift senser on trans that may be making it do this?
Old Aug 26, 2006 | 01:43 PM
randy78045's Avatar
randy78045
Default RE: Transmissoin shifting
Do they still put those valves on the back of the tranny... kant think of what theyre called right no, but if they do an its bad, it will *** up your shiftin... [:-]
Old Aug 26, 2006 | 01:53 PM
ackuric's Avatar
ackuric
tcs is one thing to check (transmission control switch)
im sure theres a few other sensors that will have that effect.
Old Aug 26, 2006 | 01:59 PM
randy78045's Avatar
randy78045
Modulator valve was what i was tryin to think of above... do they still use them on newer trannys?
Old Aug 26, 2006 | 02:23 PM
65coupe88hatch's Avatar
65coupe88hatch
i know i have one on my 88, its been changed before
Old Aug 26, 2006 | 02:24 PM
floridastangs
There is a senser on the pass. side of trans that has a vac line going to it. Is that a modulator valve?
Old Aug 27, 2006 | 03:17 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Likely. What kind of a car are you driving? There are many variations through the ages.
Old Aug 27, 2006 | 09:26 AM
corvetteguy's Avatar
corvetteguy
You did put in the correct fluid.
I added a little dextron 2 and
the trans started to work like
the fluid was low.
Put the Mercron in and all is better.
Old Aug 27, 2006 | 01:35 PM
floridastangs
The car is a 1992 2.3l W/A4LD trans. I used the right fluid and filter added a bottle of Lucas transmisson additive. I had the same problem after changing fluid as i did before. took it down the road today and it shifted from 1st thru OD fine without sliping. Then went home parked car for about 1hour Had to go to store and it would not shift through any gear. I added a tras fluid cooler to help but still the same.
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Mustangmalo
Sep 6, 2015 05:22 PM
