No tailights or guages
Old Jun 24, 2004 | 04:22 PM
SXGT's Avatar
SXGT
Default No tailights or guages
When i turn my parking lights on my center clock goes out. My tail lights wont come on but ,y turn signals and headlights work. My face guages wont light up. I checked fuses under the driver side dash , is there any other place for fuses or does it sound like i pulled a wire out some were.
Old Jun 24, 2004 | 04:27 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: No tailights or guages
Fuse, relay, or headlight switch. If your headlight switch is bad then your tail lights should still work when you press the brakes, the instrument cluster is on a different fuse than the tail-lights. They may share the same relay though, Im not sure. If your tail lights don't come on no matter what, then be looking for a relay - or maybe a fuseable link.
Old Jun 24, 2004 | 04:36 PM
TRL12087's Avatar
TRL12087
i had a similar problem with my 86, i checked all the fuses and relays and finally changed thr switch. the switch did it for me.
Old Jun 24, 2004 | 05:55 PM
e40water's Avatar
e40water
Its sounds like head light switch to me too.
96stang3.8
Sep 10, 2015 06:42 AM
90hatchLX
Oct 14, 2005 05:53 PM
db7am
Mar 2, 2004 01:49 PM
Pitviper100
Oct 25, 2003 07:21 AM
RAGNAROK
Aug 7, 2003 07:10 PM
