busted a nut
Old Aug 29, 2006 | 01:47 AM
draco529's Avatar
draco529
Default busted a nut
So I busted a screw off inside my Trickflow intake. The screw in question is on that holds down the fuel rail on the passenger side. There are two, I went with just the one thinking that would work, but the fuel pressure keeps blowing the rail off of the injector on the number 4 piston and leaking it all over. So it has become clear that I need to get the busted screw out. Any ideas as to how.
Thanks
Old Aug 29, 2006 | 02:08 AM
Obsol3te's Avatar
Obsol3te
Default RE: busted a nut
Use an easy out and get a heli-coil kit
Old Aug 29, 2006 | 03:18 AM
kartracer55's Avatar
kartracer55
ORIGINAL: Obsol3te
Careful with the easy out though. When you break them (which tends to happen) they area bitch to drill out. +1 on the Heli-coil. Depending on the size of the part, id just take it to a local machine shop (call ahead) and see if they have a couple minutes to do a heli-coil. The reason I say have them do it is because for the amount you will use a heli-coil kit, it doesnt make sense. A shop will be able to do it faster, and they will probably do a better job that we can.
Jim
Old Aug 29, 2006 | 12:02 PM
samseed101's Avatar
samseed101
I busted nut in my intake too. it's just so pretty! I can't help it.
Old Aug 29, 2006 | 12:08 PM
P Zero's Avatar
P Zero
Drill it, get a GOOD easy out (not some $2 cheapo), and then you have to go by feel. A little fore around the intake might help too. Obviously clean the gas off first. When you do get it out, use anti seize when reassembling, thatll prevent it from happening again.
-P.
lincolnshibuya
Dec 8, 2020 01:49 PM
Oct 7, 2015 07:02 PM
RCS02v6
Sep 29, 2015 01:46 PM
maestro1024
Sep 21, 2015 02:40 PM
mustangfan305
Aug 31, 2015 07:18 AM
