roller rocker?
Old Aug 30, 2006 | 06:28 PM
Sean W.'s Avatar
Sean W.
Default roller rocker?
whats a roller rocker and what are its advantages over regular rockers. oh and why is it called a roller rocker. oh,lol, and how much would a set for a V8? and for a V8, you need 16 rocker arms right.....
Old Aug 30, 2006 | 07:12 PM
Chopper's Avatar
Chopper
Default RE: roller rocker?
Roller rockers have less friction than regular rocker arms and don't wear the valve guides as fast.They also need less energy to open and close the valves.Less energy used doing things like opening valves is more torque at the crank.
http://www.jegs.com/webapp/wcs/store...tegoryId=11221
Old Aug 30, 2006 | 08:02 PM
GreyStang's Avatar
GreyStang
+1 what Chopper said
Also with roller rockers the cam lobes can be ground much steeper so the valves open/close a lot faster, giving you more effective duration.
Old Aug 30, 2006 | 08:08 PM
Sean W.'s Avatar
Sean W.
could i put roller rockers on a classic engine, like a 68' 302?
Old Aug 30, 2006 | 11:34 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Yep. You'll need to machine the heads for screw in studs as well as guide plates. That cost about $50 last time I had a pair of heads taken care of.
ORIGINAL: Sean W.
Old Aug 30, 2006 | 11:38 PM
388STROKEDLX's Avatar
388STROKEDLX
Unless it is a chevy powered Ford. No hard feelings guys. It is all out of fun.
Sixer4Life
Oct 12, 2015 04:26 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
uedlose
Sep 30, 2015 08:01 AM
Sixer4Life
Sep 28, 2015 07:05 AM
JDWalton
Sep 24, 2015 08:47 PM
