aftermarket heads
Old Jul 5, 2004 | 07:08 PM
fast83gt's Avatar
fast83gt
Default aftermarket heads
This is another one I'm sure everyone has a different opinion on.
What's the best aftermarket head.
I'm personally looking for a large combustion chamber to get a low compression ration to run alot of boost. I still would like opinions for other heads, as I don't know much about them and would like to.
Old Jul 5, 2004 | 07:20 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: aftermarket heads
I think the afr's 185's are good....using a dish piston would be best than large chamber heads but the edelbrocks have a 64cc head vs the others at 58-61cc
Old Jul 5, 2004 | 07:48 PM
fast83gt's Avatar
fast83gt
Do you know which moden Edelbrock head that is?
Old Jul 6, 2004 | 02:29 PM
callmecobra's Avatar
callmecobra
if hes going for lots of boost, 185s arent enough...but if you have an unlimited budget, Canfields are the best hands down.
Old Jul 6, 2004 | 04:34 PM
roundman's Avatar
roundman
You need to make sure the heads you pick will work with your existing pistons and the valve reliefs cut into them or you run the risk of having the pistons hit the valves. The cam lift and the rocker arm ratio also affect this piston to valve clearance so be sure to check out all the information you can before you buy something you can't use without having to change a lot of other stuff like the pistons, etc.
Old Jul 6, 2004 | 05:52 PM
fast83gt's Avatar
fast83gt
I have dished (probe fps) pistons with valve reliefs cut in them. I'll probably be running a cam with ~.515 - .520 lift and 1.6 rockers.
kevsgt
Oct 9, 2015 10:12 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
wraith777
Sep 28, 2015 10:49 AM
Sep 24, 2015 09:18 PM
