Engine swap trouble - Please help!!
Old Jul 6, 2004 | 10:57 PM
souron's Avatar
souron
Default Engine swap trouble - Please help!!
hey all,
ok well i'm in the midst of swapping a 5.0L out of a '79 T-Bird into my '85 LX the original engine that was in it was a CFI 3.8L, so the swap was going good for the most part, so i'm getting close to the end, but now i'm running into some major problems like my ignition- i dont know much about wiring in cars so i dont know how to hook it up to a keyed on source, everything else seems to be hooked up right on my ignition except that, next problem aparently there is somthing wrong with my fuel pump since when i turn the key on it primes but then wont give me any fuel after that unless i take off one of my terminals on my battery but thats just the same as turning my key off then on, then of course my tach dosent work but thats a minor thing, i think thats it that i know of, any help would be awsome
thanx
Old Jul 7, 2004 | 12:25 AM
drumaz's Avatar
drumaz
Default RE: Engine swap trouble - Please help!!
I'm not sure about the ignition bro. I just did an EFI to Carb switch and had similar problems. I replaced the whole ignition system with a DuraSpark II distributor and a Crane Fireball Ignition box and coil. That straightened me out. As far as fuel goes, i bypassed the WHOLE system. I mounted a Mallory electric pump where the old fuel filter was, replaced the in-tank pump with a pick-up and then ran my own lines up and back. Painless Wirirng makes an awesome fuel pump wiring system that is a breeze to run too. We just grabbed "switched" power on the driver side firewall nad hooked the fuel pump to that. Works great... I hate electronics!!!!!!!!!!!!!!!!!!!!!! Best of luck.. hope his helps a little bit.
Oh yeah - The only gauges that worked after my switch were MPH and Fuel.
[IMG]local://upfiles/7713/Bz776721174.jpg[/IMG]
Nurdyguy
Jan 20, 2025 04:38 PM
MusicCity615
Sep 27, 2015 12:53 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
kawiguy827
Sep 1, 2015 07:09 PM
Jacob4589
Aug 8, 2015 11:00 AM
