rattling noise
Old Sep 17, 2006 | 06:15 AM
chumouch's Avatar
chumouch
Default rattling noise
hey guys i have a problem my car seems to be loosing power and i think i know what it is but i do not know how to fix it whenever i press the gs hard i hear a rattling noise coming from the engine this doesnt happen all the time but mostly when the car gets hot then it's worts anyone with this problem before? my mechanic said it's the kind of gas i'm using but i only use the best gas and i get the same result even changed my o2 sensor help please thanks
Old Sep 17, 2006 | 11:32 AM
randy78045's Avatar
randy78045
Default RE: rattling noise
You would probably get a better response to you question if you posted it in the model specific forum... Welcome to the forums...
Old Sep 17, 2006 | 09:32 PM
03truebluegt's Avatar
03truebluegt
Welcome to the forums!
Old Sep 18, 2006 | 10:39 AM
Chopper's Avatar
Chopper
ORIGINAL: chumouch
It sounds like detonation.This is a common problem with just about every car on the road these days.You could have carbon built up in the combustion chambers that is raising your compression ratio and causing the rattling sound.
http://www.bullittarchive.com/WebHel...escriptons.htm
This is a link to noise desriptions that could be of some help.
Spraying a fine mist of water into a warmed up engine can clean out carbon but you have to know what your'e doing or you can mess things up.
Old Sep 22, 2006 | 01:52 AM
Nittro22's Avatar
Nittro22
It sounds like the same problem i am having. It almost sounds like there is something loose in the engine bay when the gas is pressed. The sound only happens though when i am driving. I first noticed the noise after i chipped my car.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
KingRando
Oct 2, 2015 08:06 AM
69Volunteer
Sep 30, 2015 10:39 AM
UrS4
Sep 30, 2015 10:13 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
