Trouble getting front springs back in HELLLPP
Old Sep 18, 2006 | 10:05 PM
MustangMike2001's Avatar
MustangMike2001
Default Trouble getting front springs back in HELLLPP
The spring needs to be curved in order to get back in place but the compressor I am using pulls it strait down. I tryed to compress just one side with strut compressors but the bolt is way too long and gets in the way. How am I supposed to get the springs back in??
Old Sep 18, 2006 | 11:10 PM
BraMas's Avatar
BraMas
Default RE: Trouble getting front springs back in HELLLPP
I used the strut spring compressors but I used one on each side. I put the side that you would wrench on more toward the top of the spring. By top I mean by relation to how it will be in the car.
Old Sep 19, 2006 | 12:15 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Did you remove the lower control arm? I had that removed when I did my springs and it went together pretty well.
Old Sep 19, 2006 | 03:09 AM
amrcnidyot's Avatar
amrcnidyot
i forced mine in by hand......didnt use a spring compressor for anything. maybe you should give it a shot?
Old Sep 19, 2006 | 04:21 AM
OnyxCobra's Avatar
OnyxCobra
ORIGINAL: amrcnidyot
+1
Old Sep 20, 2006 | 01:39 PM
MustangMike2001
I just used two compressors and tightened down more on the side I needed pulled in. It took me a while to figure out the first one but the second one I did in about 10 minutes.
Old Sep 20, 2006 | 02:21 PM
freewilly's Avatar
freewilly
I ♥ Acer
i use a inner type spring compresser, its expensive but works on all coil springs. i do suppose you took the ft. shock loose at the bottom right ?
drfister
May 3, 2018 10:38 PM
spectreman
Mar 31, 2016 09:26 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
zachary1988
Sep 1, 2015 07:58 AM
Tyoung68
Aug 25, 2015 04:31 AM
