Need a little help
Old Sep 19, 2006 | 04:22 PM
stangcrazy's Avatar
stangcrazy
Default Need a little help
Not a mustang but a 97 Explorer. I just received a call at work about the mother-in-laws explorer not running. This is all I know....97 Explorer....V6, 150-170K miles.
It starts but shutters and turns off. I do not know if it is imediate or when put into gear..automatic. My first asumption would be fuel delivery filter maybe. Or a cylynder not firing.
The car is a daily driver and is driven pretty much everday without any previous problems.
Given what I have posted ...very little..does anyone have any good ideas or a starting point to start troubleshooting?
EDIT: I will be driving 30 some miles to look at this problem reason why I am asking so I know what to take with me.
Old Sep 19, 2006 | 04:35 PM
P Zero's Avatar
P Zero
Default RE: Need a little help
Does it stay running if you keep your foot on the gas pedal?? It could be a number of completely different and unrelated problems. So some more info would be a little helpful. But the IAC (idle air control) comes to mind.
-P.
Old Sep 20, 2006 | 04:14 PM
stangcrazy's Avatar
stangcrazy
Well after I got out there I started it up and you did need to hold the gas in to keep her running. Since I had already bought the filter I went ahead and replaced it. The one that came off was fine. I drove it around the block a little bit and cam back let it idle for 20 mins and no problems. Cut it off let a sit a few and it fired right up. Mother-in-law said it started right up this morning with no problems either. I cannot explain how a new filter would fix this at all if the old one wasn't clogged. Of course she doesn't tell me about the check engine lights till after I am all cleaned up, so no codes ran on it, the light wasn't on when I started it but she said it had been going on and off. Told her if it happens again take it to a pro.
Old Sep 21, 2006 | 12:30 AM
Poobs's Avatar
Poobs
Hmmm ? Either an intermittent problem or that filter was worse than you tought. Maybe there was water in the filter and you let it out
