Coolant Sensor?
Old Jul 18, 2004 | 11:55 PM
blurbro's Avatar
blurbro
Default Coolant Sensor?
The coolant light is on in my car all the time but the coolant level is always good. I am thinking it is the coolant sensor in the overflow tank but I'm not sure. I have cleaned the entire coolant system(what a pain[:@]) even pulled the sensor out and cleaned it. It was covered in crud but it still seems to float. Must not be making contact some where. Is just buying a new sensor the best idea? Any ideas?
It is an 89 in case that helps but I think the design is the same.
Old Jul 18, 2004 | 11:58 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: Coolant Sensor?
Have you changed the thermostat. I think its in the upper supply hose where it attaches to the manifold if im not mistaken. See if its stuck or is malfunctioning.
Old Jul 20, 2004 | 12:09 AM
blurbro's Avatar
blurbro
Not real sure that is it but I'll give it a look. Thanks!
Old Jul 20, 2004 | 04:22 AM
callmecobra's Avatar
callmecobra
check the coolant resivoir tank. thats where it is on the newer stangs.
Old Jul 20, 2004 | 06:19 AM
92BOOSTED's Avatar
92BOOSTED
I agree with nomo.
Check your resevoir tank.It happens to me under hard acceleration.
Rye
Old Jul 20, 2004 | 12:11 PM
Dearborn5.0's Avatar
Dearborn5.0
FYI
There is a coolant temp sensor in your Cylinder Hear, just behind the distributor.
I do not think this is related to your problem, but just wanted to inform you.
my car doesn't have that sensor on the overflow tank...but then again, my
idiot lights dont work
well enough rambling...good luck
Old Jul 20, 2004 | 12:31 PM
WNDSOR's Avatar
WNDSOR
there is a sensor for the gauge/light on the left side of the intake towards the front, should have a wire leading to it....i'd replace that, should be cheap, and try to do it when the motor is cold...antifreeze will shoot everywhere if not...and you can check to see if the thermostat is stuck by feeling the hoses to see if they are warm and that will tell you if the water is flowing
Old Jul 20, 2004 | 08:05 PM
92BOOSTED's Avatar
92BOOSTED
Have you figured it out yet?
Rye
Old Jul 26, 2004 | 07:09 PM
blurbro's Avatar
blurbro
I think it has to be in the resevoir tank. It works just like the plastic ball in the back of toilet. It floats on what ever the fluid level is. The sensor is in the cap. I cleaned it and it worked for about a day. The light is now on again and the coolant level is fine in both radiator and the overflow tank. Think I'll get a new sensor. May have to order the whole cap and floaty thing.
Old Jul 26, 2004 | 07:21 PM
vfast's Avatar
vfast
I ♥ Acer
did you clear the computer after you did this?
