Reverse grinding.
Old Oct 8, 2006 | 02:39 AM
kylebgt's Avatar
kylebgt
Default Reverse grinding.
I own a 2000gt 5spd. When I shift into reverse it grinds, anyone else have this problem? I used redline mt-90 in my previous car which worked miracles, is it ok to use it in our transmission?
Old Oct 8, 2006 | 03:21 AM
monkeydude3's Avatar
monkeydude3
Default RE: Reverse grinding.
I don't know about that fluid, but most manual trannies will grind a little bit into reverse, it's the nature of the gear. Have you tried pushing the clutch in and waiting a few seconds, then goin for reverse?
It's just a different style of gear and has a weak synchro on it, so it's bound go grind more than anything else will.
Old Oct 8, 2006 | 12:29 PM
squad272's Avatar
squad272
My 1990 grinds into reverse alot also...
I find if I go to 1st and get the car to move just a smidge and then go to reverse the problem is solved
Old Oct 8, 2006 | 04:16 PM
kylebgt's Avatar
kylebgt
How reliable is the stock gt transmission? Are the syncros weak? < I had that problem with my previous car and it was a major headache.
Old Oct 9, 2006 | 05:25 AM
Jugador's Avatar
Jugador
reverse isn't synchromesh. i usually throw it in fifth before i put it in reverse which prevents grinding. putting it in any gear with synchros should work, but fifth is easiest since you can usually just go from one to the other in a fluid motion
Old Oct 9, 2006 | 12:50 PM
7upedition's Avatar
7upedition
^+1 thats what i was gonna recomend, as well as a tranny flush and fill at a ford dealer, if you drop the pan your only changing 3-4 qts vs. the 13 the tranyn holds, its about a $100 but well worth it, recommended every 50-60K miles
Gene K
Oct 21, 2015 11:37 PM
foxdude
Sep 24, 2015 08:45 PM
maestro1024
Sep 21, 2015 02:40 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
