difference between regular clutch and perf.
Old Oct 14, 2006 | 11:12 PM
badkarma16's Avatar
badkarma16
Default difference between regular clutch and perf.
so, i need a new clutch now, and i was wonderign what the differences between clutches are. i have seen stage 1's, 2's, and 3's, but i dont know what it all means. what are the benefits from a stock clutch. are clutches easy to install? would i need to pull engine off to get to the tranny, then to the clutch? thanks for any help you give me. erich
Old Oct 15, 2006 | 12:45 AM
GreyStang's Avatar
GreyStang
Default RE: difference between regular clutch and perf.
What kinda car do you have?
Performace clutches have higher spring pressure to grab the clutch harder so it doesn't slip as much. It also usually gives a heavier pedal for you to push too [:@] if your engine is stock then stick with a stock clutch unless you enjoy pushing on a really hard pedal
Old Oct 15, 2006 | 02:49 AM
badkarma16's Avatar
badkarma16
i have a 1999 V6 stang with a manual tranny. my clutch pedal is really high. its further up than the other pedals, and its hard to push in. by high i mean that it is like close to the seat, than i would like. i wish i could "heal-toe" shift like my old car. (geo metro 1994) lol! but yeah, how much would a stage 2 or 3 cost compared to a regular one, and how much do they run? thanks, erich
Old Oct 15, 2006 | 04:56 AM
gspfunk's Avatar
gspfunk
Like GreyStang said, the more you move away from the stock style clutch, the harder it will be to push the clutch. If you have a sixer, I wouldn't mess w/ anything more than a stage 1. It will handle all you can throw at it. I'm running a Ram HD on my modded 5.0 and it holds just fine and was only $159, so don't get caught up in spending extra cash on a performance clutch.
Old Oct 15, 2006 | 06:19 PM
badkarma16's Avatar
badkarma16
alright, thanks, ill prolly go for a stock then. ive been told that the problem i have is a "throw-out" bearing. and i should just replace the whole tranny. if thats necessary, my car will be sitting for a year.
Old Oct 15, 2006 | 06:38 PM
ionlygot6's Avatar
ionlygot6
when i replaced my clutch, that was a $30 part.... check another shop, should be pretty cheap, but labor will slit your throat
Old Oct 15, 2006 | 06:59 PM
Archion's Avatar
Archion
Most of your good clutch kits will come with the throwout bearing. If the shop told you that you needed a new tranny b/c of that, go back up there kick his *** and tell him to go back to doing oil changes b/c thats all they are apparently good for. They are just trying to stroke you for some money. A stock clutch should do you fine, but if you are looking for a better feel and a little better grab, then go with the stage one, that should hold you for quite some time.
Old Oct 15, 2006 | 07:46 PM
badkarma16's Avatar
badkarma16
lol, well, ill have to pay him a visit for sure then. i was wondering, how difficult is it to do a "clutch swap" to put a new one in? and why is my clutch pedal right now, so hard to push down? its a stock clutch im sure. thanks
Old Oct 15, 2006 | 08:31 PM
GreyStang's Avatar
GreyStang
ORIGINAL: badkarma16
==> Google's your buddy <==
Swapping a clutch isn't brain surgery, but you do have to drop the tranny & need quite a few tools & if possible a car hoist. It shoudn't be one of the first repair jobs you've tried to do so. Not sure why your pedal is "high" now but, if it's very hard to push then the throwout bearing arm might be damaged?
Old Oct 15, 2006 | 10:13 PM
badkarma16's Avatar
badkarma16
hmm. not sounding too good the more i hear. what do you mean by "car hoist" do you mean a full lift, or only a engine hoist, my uncle has a engine hoist, but no ful car lift.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
algregory
Sep 11, 2015 11:44 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
