Old Oct 27, 2015, 11:17 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrain
Print Wikipost
radiator flush
Old Jul 30, 2004 | 01:11 AM
bobby's Avatar
bobby
Default radiator flush
ok i know u might have seen this post in off topic but i didnt really find the answer to my question. ok so i drain the radiator, then i start it up and and let the hose run inside the radiator for about half hour, then i let it all drain out, ok then how much anti freeze do i put in??? do i have to do it when its hot??? how do i do any of this??? please help!!!!!! i want to do this tommorow, thanks alot
Old Jul 30, 2004 | 01:24 AM
bobby's Avatar
bobby
Default RE: radiator flush
ANYONE!!!
Old Jul 30, 2004 | 01:26 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
get the prestone flush kit and follow its instructions
Old Jul 30, 2004 | 01:31 AM
bobby's Avatar
bobby
allright, at auto zone? thanks a lot md, i heard that this can eat an old radiator, anyone know boutj this, thanks again md!
Old Jul 30, 2004 | 01:33 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
get a flush chemical with it to flush out alot of rust and corrosion. Umm yea if your radiator is rusted or corroded out and that rust and corrosion has gotten your radiator thin - I suppose removing it may make you prone to leaks - but if thats the case its better to find out now then on a hot day on the interstate.
Old Jul 30, 2004 | 01:49 AM
bobby's Avatar
bobby
true, lol, so i need some sort of chemical besides the flush kit? ok i think i got it, i drain the radiator, then fill it up with water, start it up, let it run, once it gets hot the thermostat will open and the water will begin to go down, keep the radiator full with the hose, do this for like 20 minutes or however long, then while im doing this the water will be draining out of the petcock, after i do this for awhile let shut the engine off then take the hose out and let all of the water drain out from the petcock, once its done close the valve back up, then while the engine is cool, fill it up with the prestone/water mix, let it run when its starts to go down slowly fill it, get the air bubbles out, when u cant put anynmore in it and it starts to overflow, put the cap back on, then finnaly check the overflow and if it need some fill it to the neccesary level! if im wrong on any of these steps TELL ME!!!!!!!!!!! oh and obviously read the directons for the kit also, and how many gallons of antifreeze should i buy, thanks a lot MD
Old Jul 30, 2004 | 01:53 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
No you just splice the heater hose t-fitting in, hook the water hose up there, open the radiator cap (cant remember about the petcock (haha I said pet ****) and just let the car run till the water runs clear, then put the flush stuff in with water and run for like a day or two then flush again till the water runs clear then your done - thats what the instructions say anyways.
Old Jul 30, 2004 | 01:59 AM
bobby's Avatar
bobby
a DAY or TWO, what do u mean
4cylinderplus2
Oct 9, 2020 07:45 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
Nov 18, 2015 01:34 PM
wraith777
Sep 28, 2015 10:49 AM
MusicCity615
Sep 12, 2015 07:05 AM
