trick flow
Old Oct 22, 2006 | 11:34 AM
93stangz's Avatar
93stangz
Default trick flow
hello, i just purchased a 306ci. short block and a EFI trick flow top end kit from summit racing for my 93 vert. when putting the timing chain on i wasn't sure were to set it on the crank, retard or advance. any advice on were to set the timming to get the most performance. thanx
Old Oct 23, 2006 | 02:38 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: trick flow
With an aftermarket cam, just install it straight up. The advance/retard is generally built into the grind. Unless you have a degree wheel, this is something you really don't want to mess with.
Oct 26, 2015 05:01 PM
Luke9222
Oct 22, 2015 11:55 PM
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
Sep 10, 2015 08:39 PM
Gabe_mlcc
Sep 7, 2015 11:56 PM
