4:30 gears
Old Oct 31, 2006 | 02:39 PM
SXGT's Avatar
SXGT
Default 4:30 gears
ok my Nissan had 4:30 rear end gear. how the hell can it go 135mph with only 165hp? (2700lbs)
my stang has 2.73s and tops out at 131 - 132 ish
Old Nov 1, 2006 | 12:31 AM
7arpad7's Avatar
7arpad7
Default RE: 4:30 gears
The Nissan had 4.30 gears in the rear? That is strange. Did you count the teeth yourself, or is that what someone had told you that it had in there? If it had them, then the transmission had to have some pretty high gears... I am guessing that you have an ~3500+ lb GT with an auto??? (well, even with a manual) having about 225 HP with that weight, doesn't make them look that great at top speed... The torque from the 5.0 is something else though...
Old Nov 1, 2006 | 02:11 AM
OnyxCobra's Avatar
OnyxCobra
it's probably b/c the nissan is geared much much lower than the stang giving it better leverage to overcome wind resistance. the nissan is prolly also a little lighter than the stang.
Old Nov 1, 2006 | 04:29 PM
gt96stang's Avatar
gt96stang
Swap your gears to some lower ones and I bet you'll go faster than that.
Old Nov 1, 2006 | 05:06 PM
mustangman02232's Avatar
mustangman02232
final drive on it is probalby like .50 instead of .67
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
