ball joints
Old Nov 5, 2006 | 01:45 AM
nikbait's Avatar
nikbait
Default ball joints
Hey all. I got a really bad sound coming from the front end of my 1995 v-6. Is it a ball joint gone bad? I mean it sounds like a bad sqeak and the seal on the ball joint is bad...is there any way to replace it without replacing the control arm?
Old Nov 5, 2006 | 02:22 AM
SXGT's Avatar
SXGT
Default RE: ball joints
dose it sound clanky?
Old Nov 5, 2006 | 09:56 AM
corvetteguy's Avatar
corvetteguy
Jack the front end up and use jack stands
for safety.
Have someone put their hand over the ball joint
and lightly use a board under the tire to lift
and drop the wheel while the person is feeling
for any slip movement in the ball.
If it moves, you need to replace.
Control arm stays on.
Unless you have a puller I recommend having
a local shop do the job.
$25 joint $35-$50 labor
Old Nov 5, 2006 | 05:13 PM
nikbait's Avatar
nikbait
The noise is aweful. It sounds like creaking/cracking/clanking all at once...hard to describe here without having someone hear it...
Old Nov 5, 2006 | 05:16 PM
nikbait's Avatar
nikbait
Where is the best place to buy the joint?
Old Nov 5, 2006 | 08:09 PM
corvetteguy
It is pretty much a bullet proof no frills
product.
NAPA should have it.
http://www.napaonline.com/masterpage...ont+Suspension
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
guitarman376
Oct 11, 2015 01:47 AM
marc954
Sep 29, 2015 11:18 AM
gagemcc
Sep 22, 2015 09:43 AM
