Starter Help?
Old Nov 13, 2006 | 01:02 PM
BlackFlame's Avatar
BlackFlame
Default Starter Help?
Howdy All-Im focusing now on getting the motor installed on my project 68---(the car rolls finally)-
-I checked the starter motor that came with the motor and Im not sure If I am doing it right--
-I tried checking it with a 6 amp charger, is that not enough voltage to even turn the motor? How can I tell if this starter motor is bad, before installing it on the motor??
Its an 88 302 HO motor/starter--am I missing anything?
Any help would be awesome! Thanks!
Old Nov 13, 2006 | 01:57 PM
Archion's Avatar
Archion
Default RE: Starter Help?
That is nowhere near enough to check that starter, take it to your local parts store and heve them bench test it.
Old Nov 13, 2006 | 02:03 PM
P Zero's Avatar
P Zero
ORIGINAL: Archion
+1, It needs a 12v signal, its best to do it on a bench, it has a lot of torque so it'll prolly spin outta your hands.
-P.
Old Nov 13, 2006 | 02:33 PM
BlackFlame's Avatar
BlackFlame
The 6 amp charger is 12 volts---basically 6 Amps isnt enough to even have it move? If thats the case then Ill try a car battery if anyone thinks thats a good idea--I just want to know it will crank---thanks for the input--
Old Nov 13, 2006 | 02:49 PM
Archion's Avatar
Archion
You will need about 100-125 amps to kick that thing over with no load.
Old Nov 13, 2006 | 05:01 PM
BlackFlame's Avatar
BlackFlame
Alrighty--its been a while since ive done engine thangs---So used to metal n paint--thanks all!
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
logan409
Sep 26, 2015 07:43 PM
jaiidutch
Sep 14, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
daytooday
Sep 1, 2015 09:33 AM
