Speedo went wacky
Old Nov 23, 2006 | 01:06 AM
jmac72187's Avatar
jmac72187
corner carver
Default Speedo went wacky
Earlier tonight I was pulling out of work and my speedo was going wacky. If I was going about 30, it would be jumping all round 30. It happened after I gased it a bit. It eventually stopped about 1-2 miles down the road. What could have caused this? What would this mean?
Thanks for any answers.
Old Nov 23, 2006 | 01:32 AM
65coupe88hatch's Avatar
65coupe88hatch
Default RE: Speedo went wacky
electrical issue maybe?
When i bought mine the needle jumped on me for awhile but within a week it stop and hasnt done it since...But yeah
Old Nov 23, 2006 | 03:32 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I believe you have a mechanical speedo. Sounds like the cable needs cleaned/lubed.
Old Nov 23, 2006 | 08:46 AM
corvetteguy's Avatar
corvetteguy
I agree.
Old Nov 23, 2006 | 10:05 AM
jmac72187's Avatar
jmac72187
corner carver
a 2000 has a mechanical speedo? Could I clean it?
Old Nov 23, 2006 | 09:35 PM
jmac72187's Avatar
jmac72187
corner carver
bump... anyone? can I clean it myself. It stopped but does it randomly every once in a while.
Old Nov 24, 2006 | 09:12 AM
corvetteguy
Some auto parts places sell a graphite speedo
lube kit. You have to unscrew the cable and
squeeze tube of lube down the cable.
At the same time a lube can be applied
intowards the speedometer.
Old Nov 24, 2006 | 09:45 AM
Archion's Avatar
Archion
2000 has an electrical speedo, just like my 99, it is more than likely sensor related, how many miles are on the car?
Old Nov 24, 2006 | 09:58 PM
jmac72187's Avatar
jmac72187
corner carver
Barely any... only 12,500 miles are on the car. It only does it every once in a while.
Old Nov 24, 2006 | 11:05 PM
Archion's Avatar
Archion
Hunt around there was a reset trick using the tripreset button and a key sequence, also pull the speedo sensor from the tailshaft housing of the tranny, its only one bolt and slips right out, check for any signs of cracking on the body of the sensor, i have seen them go in as short as 5k.
67LimeCoupe
Nov 25, 2015 08:55 PM
Sep 29, 2015 03:23 PM
Mr. D
Tuner Central
Aug 27, 2015 05:01 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Gregz
Aug 11, 2015 03:42 AM
