Signal Lights help
Old Aug 24, 2004 | 07:12 PM
Abhay's Avatar
Abhay
Default Signal Lights help
Hi guys, I am new to this forum, I need help regarding the Signal lights..
I have 2000 Mustang V6, Today when I put on the right signal, it started to flicker much faster than the regular frequency, the left one is Normal. I think I have changed some setting or something accidentally. Also now only one back signal bulbs flickers (middle one) and other one is off, on the left both are working fine. All the three bulbs on the right are Ok as I checked for Break signal. I dont know what cud have gone wrong, Do u think some electric board inside fried up?. Or is there any setting to change the signal flicker frequency?
Thanks for any help
Old Aug 25, 2004 | 08:09 AM
horseshoeing's Avatar
horseshoeing
Default RE: Signal Lights help
Change you bulb in the back. The one thats not working. That should fix it.
Old Aug 25, 2004 | 04:52 PM
roundman's Avatar
roundman
could be the signal light flasher is going bad too. if all the bulbs on that side are good and it still does it and doesn't light one of the bulbs, then look for the flasher under the dash and try replacing it. easiest way to find it is to turn on the signal for the left side and then listen and look for the flasher under the dash somewhere around the driver's side.
Old Aug 25, 2004 | 10:07 PM
luckythirteen13's Avatar
luckythirteen13
this always happens to my dad's Taurus. when one of the lights burns out (usually the back one) the blinker goes extremely fast. replace the bulb that is out, should fix it right up
Old Aug 29, 2004 | 09:31 PM
blown87Gt's Avatar
blown87Gt
horse is right one buld will make everything funny
blown87Gt's Avatar
blown87Gt
soory bulb
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
