idle problem
Old Aug 26, 2004 | 09:54 PM
scott8950's Avatar
scott8950
Default idle problem
my wife has a 87 coupe,when its cold it sputters and backfires every once in a while,then when it warms it wants to load up,runs rich,when it acts up you can turn off the ignition and start it right back up and it stops for a while....can anyone tell me what that is
Old Aug 27, 2004 | 05:12 AM
e40water's Avatar
e40water
Default RE: idle problem
could be a o2 sensor do you have engine light on? I will take a look at youre fuel filter / fuel pump pressure test too.
Good Luck
Old Aug 27, 2004 | 01:41 PM
roundman's Avatar
roundman
you might also want to clean the throttle body and IAC with carb cleaner. best to pull the TB off the intake to clean it really good, especially on the back side where the carbon deposits from the EGR can collect. you can get a gasket set for the TB from most good auto parts stores.
Old Aug 27, 2004 | 06:24 PM
scott8950's Avatar
scott8950
ORIGINAL: e40water
Good Luck
no the engine light is not coming on...yeah im gonna check it today..the only thing that puzzles me is when it acts up i can turn the car off and restart and its fine or if i just run the crap out of it then it clears for a short time...when the car warms up it's not anywhere nears as bad as when its cold....ive had this same problem with speed density several times.....[:@]
Old Aug 27, 2004 | 06:27 PM
scott8950's Avatar
scott8950
ORIGINAL: roundman
thanks.... gonna clean all that stuff today
Old Aug 27, 2004 | 07:11 PM
horseshoeing's Avatar
horseshoeing
How many miles does it have on it? Could it be the timing? It did it to me once.
Old Aug 28, 2004 | 12:54 AM
scott8950's Avatar
scott8950
ORIGINAL: horseshoeing
around a 101000 miles, alot of people are saying that but it is really bad when its cold and does it often then when it warms its not as bad still does it but not as often like its flooding or running out of gas and it will backfire at times but if i floor it it will pick up and clear out also when it does this its really rich [:@][:@]
Old Aug 28, 2004 | 02:11 PM
04mustang's Avatar
04mustang
timing
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
