universal joints?????
Old Aug 27, 2004 | 11:09 PM
cammedlx's Avatar
cammedlx
Default universal joints?????
when i drive my car it does fine until about 60 65 and a little vibration comes in and you can here clunking noises aroung the back of the tranny and it also clunks a little when the car gets in a situation where you have to give it more gas like if i was going up my driveway in first the car is a 90 gt with a t5 any ideas will be great
Old Aug 28, 2004 | 03:04 AM
e40water's Avatar
e40water
Default RE: universal joints?????
well it sounds like to me youre universal joint could be bad, You can tell is lift backend of youre car on jack stands, wiggle youre drive shaft if its loose try tighting the rear end bolts that hold the universal joint in place if they are tight, Then youre universal joints are no good.
Good Luck
Old Aug 28, 2004 | 04:16 PM
94Cbra's Avatar
94Cbra
From what I can tell it sounds like a U-joint to me too. Its a cheap and easy fix, shouldnt be any trouble.
Old Aug 28, 2004 | 04:20 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
yea what they said check your driveshaft for play in it
Old Aug 29, 2004 | 02:03 AM
Acer2428's Avatar
Acer2428
Site Mod
PLay with your shaft and see if anything happens..... Errr.... No....Crap
Old Aug 29, 2004 | 09:28 PM
blown87Gt's Avatar
blown87Gt
bolts are prob loss unless someone had drove the crap out of your car
Old Aug 30, 2004 | 10:02 AM
horseshoeing's Avatar
horseshoeing
Could be a bent drive shaft. That can make a u-joint go bad. If if still does the vibration, Jack up the rear end and run the motor and turn the drive. Look under the car and you can see what it is doing. Be careful doing this!!! Don't go 60mph!!!
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
marc954
Sep 29, 2015 11:18 AM
gagemcc
Sep 22, 2015 09:43 AM
