Steering Stuff
Old Aug 28, 2004 | 11:48 PM
captaindude's Avatar
captaindude
Default Steering Stuff
I've got a couple of things I was wondering about. I have an 88 Mustang 4 cyl. I want to replace the steering wheel with a smaller one. I've got all the parts, and I've tried using a steering wheel puller to get the old wheel off, but it won't budge. I've stripped out the threads in the original holes that the puller uses, along with the threads in subsequent holes I've tapped. I think the metal's too soft to old when I try to use the puller. Anybody have any ideas on how to get the wheel off? A 2 hour job has now lasted all day.
Also, there's a "dead spot" in my steering...basically about a sixth of the steering wheel's diameter...the steering wheel moves but the car's wheels don't. Any ideas on what that might be?
Thanks for your time.
Old Aug 29, 2004 | 11:30 AM
Chopper's Avatar
Chopper
Default RE: Steering Stuff
Do you have ALL the nuts off the wheel?It shouldnt come off that hard.As far as dead spots,the steering rack has worn places in the internal mechanism.A car of this age probably has a lot of play throughout the system and it all adds up at the wheel.
Old Aug 29, 2004 | 12:57 PM
vfast's Avatar
vfast
I ♥ Acer
your rack is worn and I bet the knuckle shaft is also as is tie-rod ends etc
Old Aug 29, 2004 | 07:34 PM
captaindude
All I saw was the one bolt that threads into the steering shaft. I talked to someone else and they suggested, also, that there were multiple bolts/nuts, but I can't find them, and I can't find them in the mustang book I have. I managed to get some bolts to not strip and used the puller again, but the steering wheel still didn't budge, but yet the bolts started bending.
Thanks also on the answers regarding the dead spot. I was wondering if it ws the result of normal wear or was a major danger thing.
lincolnshibuya
Dec 8, 2020 01:49 PM
CS2007
Jun 25, 2019 09:45 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
allenmaty
Sep 24, 2015 09:17 AM
stark777
Sep 21, 2015 12:46 PM
