How do U modify stock MAF ?
Old Dec 10, 2006 | 08:03 AM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: How do U modify stock MAF ?
Poobs, if all you have is a non-PI pulley/catback/mid-pipe GT you should leave your MAF alone. It's far too risky to fool around with it, especially without getting it on a dyno before you take the first trip down the road.
You should be far more concerned about a PI swap or forced induction than looking for ways to 'tweak' your MAF. It'll never net you gains worth the research/labor/risk involved, ever.
Old Dec 10, 2006 | 01:17 PM
Poobs's Avatar
Poobs
Dan
Thank you much for the advice. You are correct. This is purely tweaking for fun and hopefully too learn a thing or two.
As I meantioned earlier, I have a CL MAF that seems to be doing a great job plus a spare MAF that I can bolt back on if there are any doubts about the ground up MAF housing.
I was looking at the center post piece that I cut out of the stock MAF and there was another way that I could have gone - I could have also ground down the thickness of the center post. The original casting is quite thick
Later
Old Dec 10, 2006 | 06:37 PM
Poobs's Avatar
Poobs
Well, I installed the hacked up MAF housing and the car runs fine.
I did not pull the battery wire to re set the computer nor drive long enough to get a CEL
The car feels much like it did last time I put the stock MAF back on. The torque peak seems lower in the RPM range and it may have lost a bit of power on top end.
There is no pinging that I can detect.
My volt reading on the C&L MAF at idle were 14.28 between terminals A-B and .89 between C-D The modified unit reads 13.69 and .80 respectively
Haven't found if the above is good or bad however[:-]
Old Dec 12, 2006 | 01:06 AM
Sap's Avatar
Sap
What are you using to modify the tune, monitor the car, etc.
E.
Old Dec 12, 2006 | 11:20 AM
Poobs's Avatar
Poobs
I have a volt meter, oscilloscope........ Unfortunately I do not have anything accurate to measure fuel mixture etc.
What I have been using is my nose to smell unburnt fuel at idle.
Seat of the pants, gas mileage and the eventual change in color of the spark plugs
Old Dec 17, 2006 | 12:01 AM
Poobs's Avatar
Poobs
Done quite a bit of driving since my last post on this topic - no CEL or adverse effects yet.
Today I was throwing the car around a bit - It feels virtually the same as with the C&L 80mm MAF. It may even be a bit more responsive to the gas pedal on the bottom end, when you get on it however the top end is not the same as with the C&L.
Driving the car now reminds me of a car with a smaller carburetor or driving with a carb that has real small primaries.
I'm thinking of wiring in a cheap air fuel gage. I know it will not be the same as a calibarted wide band gage but it will tell the realtive diferences between the C&L , stock and modified stock MAF
Old Dec 17, 2006 | 04:02 PM
Dan04COBRA's Avatar
Dan04COBRA
Get it on a dyno and see if it's made any differences. I'd be shocked if it did, but it'd be worthwhile information to someone else since it is essentially a free mod.
Dyno dyno dyno
Old Dec 17, 2006 | 07:10 PM
Poobs's Avatar
Poobs
Unfortunately I have no funds for that right now[&o]
I agree however, my butt tells me its about the same as before - maybe just a shift in the torque peak
Old Dec 20, 2006 | 04:27 AM
vristang's Avatar
vristang
Don't hose around with your MAF, it isn't worth it.
Go to C&L and find out what the CORRECT sample tube is, and use it.
http://www.cnlperformance.com/calibration.html
Either that or go back to the stock assembly (if it is still intact).
(C&L does not publish their sample tube diameters, but I have most of them listed on my site. Sometimes the sample tubes lose their color, or are mis-colored)
Truth is, you have no idea how the car is running as you can't monitor AFR or the KAMRF's with a voltmeter or scope.
Until you have checked both the KAMRF's and AFR, you can't say if the engine is running properly or not.
The 'Nose' test is obviously lame.
Using a voltmeter to measure the output of the MAF/MAS will tell you basically nothing. You also have to know how the computer will interpret that voltage.
The MAF/MAS uses a conversion factor to convert airflow to voltage. (not really how it works, but it makes the point)
Once the computer has the voltage... the computer uses a conversion factor to turn that voltage back into an airflow number.
By modifying the internals of the MAF tube, you changed the conversion factor that the MAF/MAS uses.
The bad part is that the computer doesn't know that things have changed.
With your mods, there is no reason to mess with the MAF/MAS.
There are better things to spend your time/money on.
sorry it's so random,
hope it helps
jason
Old Dec 20, 2006 | 10:05 AM
Poobs's Avatar
Poobs
Thanks Jason. I apreciate the advice and I agree with you.
Actually the C&L has what should be the correct tube for my motor mods etc.I also tried two other tubes and both of these triggered CEL. The codes were something to do with lean bank or something to that effect.
