How do U modify stock MAF ?
Old Dec 20, 2006 | 09:47 PM
  #21
vristang's Avatar
vristang
Default RE: How do U modify stock MAF ?
ORIGINAL: Poobs
Thanks Jason. I apreciate the advice and I agree with you.
Actually the C&L has what should be the correct tube for my motor mods etc.I also tried two other tubes and both of these triggered CEL. The codes were something to do with lean bank or something to that effect.
The lean bank 1 & 2 codes would make sense.
If you suspect something isn't dead right, then it is worth the effort to measure the C&L sample tube.
I have heard from several folks in the last year, who had the wrong tube.
With the addition of a custom tune (tweecer/pms or professional dyno) you could realize some benefit from a stock MAF with the bars removed.
That can be tough on the budget though.
Good Luck Poobs!
Old Dec 21, 2006 | 01:09 PM
  #22
Poobs's Avatar
Poobs
Thanks man !!!
Old Dec 21, 2006 | 11:54 PM
  #23
Lizardbreath's Avatar
Lizardbreath
DONT GRIND YOUR MAF. IF YOU WANT A BIGGER ONE BUY ONE....even then you will end up running lean without a tune.
Old Dec 23, 2006 | 11:37 AM
  #24
Poobs's Avatar
Poobs
It makes sense that it would run lean since by removing the center post you let more air in.
Actually, the article that I read before doing the mod also says to drill out the tube - I guess to try to richen the mixture back to the right point. I skipped that step since the car seems to run fine.
If I ever get a wide band fuel gage. I'll check out what the transfer function isdoing with the mods....
Old Dec 24, 2006 | 12:09 AM
  #25
vristang's Avatar
vristang
ORIGINAL: Lizardbreath
Is that a Water Dragon in your sig?
Hope you didn't eat her... LizardBreath
Jb145700
Aug 21, 2022 06:37 AM
Gene K
Oct 21, 2015 11:37 PM
ccdguy
Sep 19, 2015 05:20 PM
dunebuggydude11
Sep 13, 2015 03:03 PM
IronRaptor
Sep 9, 2015 08:10 AM
