Best 2v head gaskets
Old Dec 5, 2006 | 12:54 AM
Nthe11s's Avatar
Nthe11s
Default Best 2v head gaskets
i am installing a turbo system in a 00 crown vic that has been heavly modifed. what are the best head gaskets to handle 20 or so pounds of boost.
Old Dec 5, 2006 | 09:07 AM
patriot98's Avatar
patriot98
Default RE: Best 2v head gaskets
20 or so lbs of boost on pump gas? You crazy man.
&^^^^^^ I mean that
There are crown vic forums with a ton of friendly people. [:'(]
www.crownvic.net
www.crownvic.us
You will need a stud kit, and a strong engine. And Im hoping you not doing this with stock cast pistons.. As far as gasket goes, go to jegs and find one that looks good for you.
Old Dec 5, 2006 | 02:00 PM
Nthe11s's Avatar
Nthe11s
Let me rephrase my question
I have a fully built 2v 4.6 Crown Victoria that I am upgrading to Turbo(S). I am going to inspect the heads and block. When I put it back together I would like to use the best head gaskets to date. What Head gaskets is everyone using to handle 20 or so pounds of Boost?
20lbs will be for Track (race gas)
12 to 15lbs will be for Street (pump gas)
patriot98 I may be crazy [sm=smiley4.gif]but u my friend are delusional and in need of help (Ritalin). Where did I say I was using Pump gas with 20lbs? If I remember correctly I ask about the best head gasket not ur 2 cents…. And the links you have there most of the people there have not gone to the extreme like I have. If they have they went with 4v or 5.4.
And if you think your Daily Driver can hang bring it….
kevsgt
Oct 9, 2015 10:12 PM
Dathan
Oct 5, 2015 05:52 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
wraith777
Sep 28, 2015 10:49 AM
