4 to 5 bolt rotors
I want too change my 87 ,used to be 4 banger, project car from 4 bolt to 5 bolt so i can use an old set of cobra r wheels.
does anyone know of a rotor available for an 87 4 banger car that is 5 on 4.5 pattern? or can i take spindels off of a 94,95 mustang?
thanks
brad
thanks
brad
Brad to switch you can swap it over to 5 lug by getting the front brake setup off of a licoln mark 7. Youll need the rotors, bearings, calipers, and the rear axles. They should be a direct bolt on, its p[robably a good idea to get the rear brake setup off of the mark as well, I believe its disk.
-P.
-P.
maestro1024
Sep 21, 2015 02:40 PM
Sep 16, 2015 07:53 PM
