Fuctionizing the hood scoop
Old Dec 20, 2006 | 07:05 PM
MustangMike2001's Avatar
MustangMike2001
Default Fuctionizing the hood scoop
I'm about to functionize my hood scoop and I'd rather remove the hood liner than cut a hole in it. Just wondering if the heat from the engine will damage the paint or anything before I do it?
Old Dec 20, 2006 | 10:47 PM
bobbyward's Avatar
bobbyward
Default RE: Will removing the hood liner cause any problems?
mine has been gone for years and hasn't done so
Old Dec 20, 2006 | 11:03 PM
wythors's Avatar
wythors
There are absolutely no ill effects to removing the hood pad other than sometimes there's no paint on the underside of the hood where it's covered.
Old Dec 20, 2006 | 11:38 PM
GreyStang's Avatar
GreyStang
ORIGINAL: MustangMike2001
I'm about to functionize my hood scoop and I'd rather remove the hood liner than cut a hole in it. Just wondering if the heat from the engine will damage the paint or anything before I do it.
Have fun sopping all the rain water off your engine
Old Dec 21, 2006 | 01:07 AM
MustangMike2001
ORIGINAL: GreyStang
Not sure how yet b/c I just started working on it tonight but I'm going to rig up some easy way of closing it off for when it's raining.
Old Dec 21, 2006 | 10:14 AM
BraMas's Avatar
BraMas
What are expecting to gain by doing this?
Old Dec 21, 2006 | 10:16 AM
P Zero's Avatar
P Zero
Not destroying his hood liner. And ram air, are his intentions. Ive had mine off for over a decade with no ill effects.
-P.
Old Dec 21, 2006 | 11:10 AM
wythors's Avatar
wythors
Considering that the air intake for the engine is inside the right fender and that there will be no outlet for any air hypothetically brought in by "functionalizing" the scoop to increase engine cooling, this is a complete waste of time.
Old Dec 21, 2006 | 01:06 PM
Poobs's Avatar
Poobs
Matter of fact the functional hood might distrupt the flow of air and make things worse.
Old Dec 21, 2006 | 01:45 PM
amrcnidyot's Avatar
amrcnidyot
its not gonna do sh*t. it will give him a "functional" hood scoop that will allow some cool air into the engine bay. its not ram air at all. it would look a lot better if you did just cut a hole that was about the size of the opening in the hood liner. the underside of the hood isnt exactly pretty.and you better come up w/ somethin to stop water from gettin in. youll be kickin urself in the a$$ later if you dont.
