cam pin shearing
Old Dec 23, 2006 | 06:53 PM
Hardcore83's Avatar
Hardcore83
Default cam pin shearing
I have a 85 mustang with a 331 that was running when I bought it and the cam bolt backed out sheared the pin in the cashaft ruined the whole top end so I put all new valves pushrodscam ect. but when i went to adjust the vavles it sheared the pin again any ideas on the cause by the way it has flat top pistons eldelbrock preformer rpm heads and a x303 com
Old Dec 24, 2006 | 04:13 AM
P.S.I.cho's Avatar
P.S.I.cho
Default RE: cam pin shearing
with clat top pistons and the x cam first thing id do is check piston to valve clearance, also make sure your using the right lifter/cam combo
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Nov 18, 2015 01:34 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
