GAS
Old Sep 15, 2004 | 03:35 AM
Redline03GT's Avatar
Redline03GT
Default GAS
Any of yall have this problem where it seems like exhaust fumes are comin through your A/C system? My dad is sarcastically worried that I'll die of carbon monoxide poisoning and I was wondering if its normal to smell this, or if it really is a smoker's cough I now have.[sm=smiley11.gif]
Old Sep 15, 2004 | 03:59 AM
94Cbra's Avatar
94Cbra
Default RE: GAS
Ive never had that problem. Are you moving down the road when you smell it? If not it could be your exhaust creeping under the car to your engine and it getting pulled into the vent system. Im stupid though...
Old Sep 15, 2004 | 04:05 AM
Guest
Guest
Posts: n/a
Default RE: GAS
haha that is definitely NOT normal... might try to search your exhaust for holes.
Old Sep 15, 2004 | 04:07 AM
e40water's Avatar
e40water
Default RE: GAS
No thats not normal to have that happen, I would thin you have a leak some where around the cat or header area.
Good Luck.
Old Sep 15, 2004 | 04:36 AM
luckythirteen13's Avatar
luckythirteen13
Default RE: GAS
when i first start up my car or when it idles to long at a stop light i can smell my exhaust. but i have no cats and the exhaust dumps before the rear axel so i have an excuse. no you shouldnt smell exhaust in your a/c
Old Sep 15, 2004 | 12:06 PM
roundman's Avatar
roundman
Default RE: GAS
I would check the entire exhaust system for leaks starting with the header gaskets and make sure there are no leaks anywhere. With the car idling, have someone hold a rag over the tailpipe ends and listen closely for the hissing sound of leaks and then fix em!
Old Sep 15, 2004 | 04:40 PM
IownaMustangNow's Avatar
IownaMustangNow
Default RE: GAS
when u start your car and its idling, turn everything off, your music and everythign taht makes noise except the engine, if u hear a little hissing sound it could be a vacuum leak or an exaust leak sumwhere, but i only know this because my moms cougar does it, plus many other problems but thats another story
Old Sep 15, 2004 | 07:14 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: GAS
look at the exhaust for any carbon this will lead you to a leak.....is this car running rich or do you have a fuel leak as 1 drop will make the smell
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
