swapping 4.6 into slk230
Old Dec 27, 2006 | 11:19 PM
02KBGT's Avatar
02KBGT
Default swapping 4.6 into slk230
i got out of work at 4am today and i went to dunkin donuts and i saw a slk230 parked in the parking lot. it seemed like the 98 model and i was wondering if anyone has heard of someone swapping a v8 into this car. it seems small but the front doesnt seem to be too small to fit a 4.6, and maybe even a nice little kenne bell lol...seems like it would be a very fun car to drive..
has anyone seen this before?
Old Dec 27, 2006 | 11:29 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: swapping 4.6 into slk230
I am thinking that thr 4.6 will not fit without a ton fab work. 4.6's are very wide and deep and that car seems pretty small. Of course anything is possible with enough money but you had better plan speding at least $10,000 unless you own a fab shop and can do the work yourself.
Old Dec 27, 2006 | 11:34 PM
GreyStang's Avatar
GreyStang
Hey they stick Ford V8's into Miatas so, anything's possible but,.,
Give it a shot if YOU are doing the work
If you have to hire someone else to do the swap then the cost will be too high
Old Dec 28, 2006 | 02:31 AM
droptoppony's Avatar
droptoppony
wouldn't it be easier and cheaper to turbo that engine? Its a 4V isn't it? Those Mercedes respond well to boost.
Old Dec 28, 2006 | 11:11 AM
wythors's Avatar
wythors
It's already supercharged. The "K" in SLK stands for kompressor.
FWIW, this is an incredibly stupid idea.
Old Dec 28, 2006 | 12:05 PM
MustangMadness7's Avatar
MustangMadness7
It depends what your goals are. If your goals are to have a high HP car that is fast, then you would be better off putting the money into the engine already in it. Their SC 2.3 has a bit of potential. If you just want something very original, then go for it. A built 4.6 with a KB on it would be an interesting swap. Plan to spend in the range of 9-12k for the swap though.
Old Dec 28, 2006 | 05:54 PM
Colorado_Mustang's Avatar
Colorado_Mustang
It'd be easier to use a OHV Windsor engine...they are A LOT smaller than the 4.6L.
Old Dec 28, 2006 | 10:03 PM
JD1969's Avatar
JD1969
ORIGINAL: Colorado_Mustang
Thats what I was getting at, but I did'nt want to waist too much time in this thread.[&:][8D]
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
