Beefier Rear End
Old Sep 21, 2004 | 02:09 AM
bobby's Avatar
bobby
Default RE: Beefier Rear End
thanks!!! ill look at that, what kind of locker did they put in the that silver wagon on hp tv? thanks again cobra
Old Sep 21, 2004 | 02:33 AM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
ARB's.. hehe, I prefer OX though. Less chance of line damage. Yeah, I've noticed that in the Mustang world seems like everyone runs a Auburn unit. In the Jeep/Off road world brands like Detroit, OX and ARB dominate. I had a Detroit in the back of my Jeep, kinda quirky on the road, especially when shifting from 1st to 2nd. I can't imagine how squirly it would be with a V8 instead of a 4cyl.
Regular Detroits cost around $500. The electrac (electricly operated) I think costs around $800.
C-clips... in axles like the Ford 8.8 and Jeep Dana 35 on the end of the axle shaft where it goes into the carrier there are c-clips that hold the axle into the carrier. If you break a shaft ( don't know how common it is in mustangs, but it's pretty common on D35's) the axle shaft and wheel/tire will slid out of the axle tube. Somebody correct me if I'm wrong... C-clip eliminators bolt a flange on the axle shaft to the axle tube so your axle/wheel won't come off if you break a shaft.
Old Sep 21, 2004 | 12:28 PM
roundman's Avatar
roundman
ORIGINAL: Grimace5.0
you're close but not quite dead on with that explanation. the axles with C-clips have a roller bearing that is not pressed onto the axle shaft and the axle just slides right out if the C-clip is removed or the axle snaps under load. the C-clip eliminators use a press on axle bearing with a press on retainer which keeps the axle from moving on the shaft and the flange bolts up between the bearing and the axle hub to keep the whole thing inside the tube should the axle break.
Old Sep 21, 2004 | 10:45 PM
bobby's Avatar
bobby
I see! thanks!
Old Sep 23, 2004 | 01:45 AM
Obsol3te's Avatar
Obsol3te
Was talkin to some people at the track today.
Thinkin about going witha Detroit Locker now
They were saying the old ones made a nice amount of noise
But the ones they have out now and nice n quiet.
Just gotta start savin my beans...
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
