PLZ help me with this door noise
Old Jan 5, 2007 | 05:55 PM
hookedonkronik's Avatar
hookedonkronik
Default PLZ help me with this door noise
Whenever I open my door my car gives the loudest clunking noise of metal on metal.
When I purchased my car (1997) two years ago, I had noticed the dealership I got it from put a fair amount of white/yellowish type lubricant or grease all over the hinges inside where the door connects with the body.
Does anyone know the best method of applying this grease (I cant think of what to use....a ruler maybe?? i dont know), and also what would the type of grease be called? Hinge grease? I'm assuming I can pick some up at a local hardware store or Canadian Tire
Thanks
Old Jan 5, 2007 | 11:17 PM
Sacmo's Avatar
Sacmo
Default RE: PLZ help me with this door noise
Check the clearence between the door and fender, It may be rubbing there... I've always found WD40 works good on the hinges but you have to give it a squirt every couple of months...
Old Jan 6, 2007 | 01:50 AM
whiterabit998's Avatar
whiterabit998
From: vids> http://vids.myspace.com/index.cfm?fusea
yea that happend to me too, its problly the fender, just pull up on it a little
Old Jan 6, 2007 | 06:50 PM
DKGreenMetallic98's Avatar
DKGreenMetallic98
I had this problem when I got my '98 on the driver's door. it squeaked real loud and made a clunking noise I squirted some WD40 in there and the squeaking went away. and never came back. the clunking noise kinda stayed there for a while and went away. I dunno if it was the 40 or what but it's not there anymore. try the 40 out.
Old Jan 7, 2007 | 09:27 AM
corvetteguy's Avatar
corvetteguy
You could use some bearing grease
on the door hinge mechanism. Also
lithium grease.
jerrytubes
Oct 23, 2015 12:11 PM
KingRando
Oct 2, 2015 08:06 AM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
