331 stroker
Old Jan 10, 2007 | 06:29 PM
phil k's Avatar
phil k
Default 331 stroker
can anybody please tell me if i have to notch the engine block (87- 302) for my 331 stroker kit from probe.
nobody seems to be able to give me a straight yes or no. some say yes some say no
please help
cheers, phil
Old Jan 10, 2007 | 09:57 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: 331 stroker
Not likely. But, as with any stroker, you'll want to check the clearances upon assembly to verify you'll have no problems.
Even 347's don't always need clearances....depends mostly on the block and the depth of the cylinder walls.
Old Jan 10, 2007 | 11:48 PM
Fosters82GT's Avatar
Fosters82GT
ORIGINAL: phil k
please help
cheers, phil
Hey Phil,
My husband has a 337 stroker in his Tiger, which is a 3.3" stroke, .030 over bore, and yes you need to notch the bottom of the bores. Ford Performance Solutions did the machine work on this block. Also, if you have questions aboutyour set-up,you can ask Probe about it since you're getting the stroker kit from them.
Hope this helps.
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
MonsterBilly
Aug 12, 2015 12:01 PM
