302 question
Old Jan 22, 2007 | 04:33 PM
jrook's Avatar
jrook
Default 302 question
I have a 68 302 block punched .30 over and am wondering if I can use the block on my 89 5.0 motor and if so what mods are needed.
Old Jan 22, 2007 | 09:44 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: 302 question
you have two blocks and you want to use both?? im confused by your question.
the parts are interchangable if thats what your asking. the 68 block wont be a roller block so you will either need to have the valley drilled and tapped for the spider or you will need to run special lifters.
Old Jan 23, 2007 | 12:01 AM
Colorado_Mustang's Avatar
Colorado_Mustang
You'd be better off machining your existing 5.0 block, honestly. The older block will fit, but, as mentioned, you won't have a roller cam. In addition, you'll have to buy new push rods and most likely an adjustable valve train to compensate for the minor block and head height variations.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
69Volunteer
Sep 30, 2015 10:39 AM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 30, 2015 03:48 AM
treesloth
Sep 28, 2015 07:03 AM
