Gear Ratio's
Old Jan 22, 2007 | 07:25 PM
Crsytal Ice's Avatar
Crsytal Ice
Default Gear Ratio's
hey, im trying to calculate the gears in my jeep, does anyone kno how to so this but just spinning the tire and watching the revolutions of the tire and on teh driveshaft?...i kno there is a way, i just dont kno how to do it. if anyone could help me out that would b great.
thanks.
Old Jan 22, 2007 | 08:50 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: Gear Ratio's
Easiest way. Spin tire one revolution, count how many times the driveshaft turns.
Examples....... 3 1/4 turns=3.27`s
3 1/2 turns= 3.55`s
3 3/4 turns= 3.73`s etc........
Old Jan 22, 2007 | 09:02 PM
Crsytal Ice
ORIGINAL: sprostang
3 1/2 turns= 3.55`s
by that method i has 1.55's......and i kno thats not right, i turned the wheel one revolution and the shaft turn 1.5 times.......
Old Jan 22, 2007 | 09:10 PM
sprostang's Avatar
sprostang
I ♥ Acer
Now that aint right. I bet it has 3.55`s. Can you read the tag on the diff cover?
Old Jan 22, 2007 | 09:38 PM
threeg502's Avatar
threeg502
ORIGINAL: Crsytal Ice
ORIGINAL: sprostang
3 1/2 turns= 3.55`s
You might need helpers to spin both tires equally. Your differential will throw off the number otherwise. It's doin' a one wheel peal!
Each of you mark a tire
Old Jan 22, 2007 | 09:59 PM
Crsytal Ice
good point bout the diff, and no i cant read the cover of the diff, plus the 31" tires play a part too
Old Jan 23, 2007 | 12:04 AM
Colorado_Mustang's Avatar
Colorado_Mustang
You might try turning the driveshaft with both rear tires off the ground. They should spin fairly equally unless you have a dragging brake or bad bearing.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
