expert help needed!
Old Oct 7, 2004 | 04:58 PM
tommyboy1989's Avatar
tommyboy1989
Default expert help needed!
Can some one tell me how to put in a new starter and starter seleniod and/or tell me a website that would help me?
Old Oct 7, 2004 | 05:16 PM
pichinco's Avatar
pichinco
Default RE: expert help needed!
Buy a Haynes or Chilton's manual. Step by steps with pictures...and most gotchas.
Old Oct 7, 2004 | 05:19 PM
Jeffs_GTstang's Avatar
Jeffs_GTstang
I would suggest investing in a Haynes manual. The $15 is well worth it in saving time and even money. Plus they cover just about everything with detailed instructions and photos, and tell you how to do work the RIGHT way. Good luck...
Old Oct 7, 2004 | 07:28 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
Its easy. if you havea 5.0, without long tubes. There are 2 bolts on the starter below youre exhaust manifold on passengers side. Remove the 2 bolts. Of course remove youre battery cables from battery first. then proceed. To replace youre starter solonoid its on youre fender on drivers side, remove the nuts and replace. Make sure to get all nuts very tight, because youre working with high voltage. Thats it.
Old Oct 7, 2004 | 11:30 PM
roundman's Avatar
roundman
are you sure both the starter and the solenoid are bad?? I would get this checked out first before you waste money on parts you don't need! it could be as simple as cleaning the main connection at the starter or replacing the main cable to the starter if it's old and gotten lots of corrosion on it as this kills the amperage it can deliver to the starter. when doing any electrical work, always disconnect the NEGATIVE battery cable first too. this way if the wrench slips on the postive post, you don't risk getting a big spark and/or shock if it hits the body while still touching the postive post.
ASF88
Sep 3, 2015 06:53 AM
Figure8allday
Aug 22, 2015 11:11 AM
defarmer
Aug 13, 2015 06:40 AM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
Mr. D
Wheels & Tires
Aug 8, 2015 05:43 AM
