clutch cable keeps breaking
Old Jan 24, 2007 | 03:20 PM
gotasister's Avatar
gotasister
Default clutch cable keeps breaking
im on my 5th clutch cable in the last 5 months...i have a stage 3 clutch, does this happen to anyone else????
Old Jan 24, 2007 | 09:28 PM
rallycar01's Avatar
rallycar01
Default RE: clutch cable keeps breaking
At one point i had a cluch cable that broke like every week...Found out that after i pulled back the carpet and looked at the firewall there is a bushing where the cable runs threw from the clutch threw the firewall to the pedal.... my cable kept fraying little thread at a time where i would have to push so hard on the floorboard b/c it was streched and would finally broke....Check the bushing! it might be warn out and the cable is rubbing back in forth on the firewall causing it to fray and break...You might be able to order a bushing i duno...i just went to the hardwear store and bought a 2 inch thick hard plastic tube, cleaned up the firewall wherethe old bushing was disconected the cable put the tube in the hole in the firewall and ran the cable back threw and then hooked it back up....never broke since...been 4 years.....good luck
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
