engine install
Old Jan 26, 2007 | 10:27 PM
351W THUNDER's Avatar
351W THUNDER
Default engine install
wen i took my motor out to rebuild i had to keep in the training because my plow frame was in the way... i just finished the motor and going to put it in... wat do i look for wen putting it in to the tranning is it difficult lining everything up...
Old Jan 27, 2007 | 01:17 AM
hotrod7687's Avatar
hotrod7687
Default RE: engine install
I assume your talking about bolting the engine to the transmission?
It can be tricky sometimes to get them lined up with the tranny still being bolted up. The easiest way ive found is to lift the trans up so that the bellhousing is angled upward as much as possible. Tilt the engine to where the flywheel is tiltes slightly downward. The trick is to have the engine flush with the trans not sitting or twisted to one side.
It might take a few tries to get it all lined up, but as soon as you see that you have it close enough to get a bolt started then bolt that hole in. It gets easier from there, just work with it until you can get more bolts started. When you have a bolt on each side, just tighten them down a little at a time until all the bolts will fit.
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
Design1795
Jan 24, 2017 10:38 PM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Design1795
Aug 24, 2015 04:41 PM
